We recived a broken HC2 at the office. Reporting that an end-user can`t connect to the HC2. Can`t find the HC2 with Fibaro finder nor using Advanced IP Scanner (looking for a mac adress)
I have tried using the backup IP adress: 192.168.81.1, adjustig my computer to 192.186.81.x. Still cant find it with Fibaro Finder / Advanced IP Scanner.
Tried regular boot multiple times with and without Recovery Stick plugged in. When I did regular boot. ONLY the power LED was lit up.
And yes, I know the ethernet port I used has a direct connection to my computer. (As i use it on a daily basis.)
Any suggestions on this? Is there some sort of "Quick fix"? Or do Fibaro need to take a look at this.
HansAvlund 0
Hello!
Thanks!
Best regards Hans
Link to post
4 answers to this question
