Messenger problem
I have the problem if two or more controllers added to one cloud account. It's possible to chose only first controller.
1. Sending fist command:
> List Home Center devices.
2. Answer:
>2 home center devices found. Please choose the number from the list. Number 1. HCL-023923,  Number 2. HC2-025252.
3a. Command for select first controler:
>Set home center device to the number 1
4a. Result
>Home center selected. How else can I help you?
3b. Same 1, 2 for second controller and:
>Set home center device to the number 2
4b. Result
>I wasn’t able to select Home Center. How else can I help you?
10 answers to this question
Try answer: Number 2
Edited by Jacek Stark
    I checked like in fibaro knowledge "Set home center device to the number 2." and "number 2" too. No difference. For first HC on list work fine, for second every time give error.
    @drboss  You need write command "List Home Center devices" ever befor you choose number HC. I have 3 HCx and this work for me fine.
    @Jacek Stark you are lucky ;) but pls look my fist point in my first post, I doing this at begin but :( and.... I didn't have a good result like you
    @drboss a najlepsze jest to że piszemy po angielsku :D.:P
    Tak @Jacek Stark, ale ta część angielska forum jest niestety bardziej dynamiczna,cóż relacja ceny do zarobków i no skala rynku na takie produkty robi swoje. Z drugiej strony fajnie że do niedawna polska firma tak ładnie zawojowała świat i miejmy nadzieję że Włosi z NICE utrzymają zespół i że dalej w PL ;-)
    Forgive us admin, we are going back to English
    Edited by drboss
    Primo:
    Quote
    3. Threads named: "Problem", "Help", "device name", etc will be deleted immediately without any notice and the user will be warned. Give other users a hint what your thread is about in the title.
    Secundo:
    Use English or ask the admin to move the topic to the Polish Forum - (dziękuję za zreflektowanie się :P)
    Tertio:
    @drboss , both gateways are available via remote access? Are they connected to each other - meaning one is a master while the other one is a slave?
    Yep, that's the way it's going to be ;)
    Both have remote access. They work as separate systems in two locations.
    Guest chaicka
    Just sharing for those who are using Messenger or going to use Messenger to control their home automation.
    @chaicka , come on - the same thing was with Apple when they requested the backdoor to iPhones. Don't start the panic.
    Moreover, the post does not address the issue so it does not belong here.
    @drboss , moving to
    And locking this thread.
