Bludger 0
G'day All,
Just giving you a heads-up regarding a defect in the LUA code generator for the Aeotec Garage Door Controller. Specifically, when there is a timeout applied to the trigger.
if (( fibaro:getValue(72, "state") == "Open")) then
setTimeout(function()
local delayedCheck0 = false;
local tempDeviceState0, deviceLastModification0 = fibaro:get(72, "value");
if (( fibaro:getValue(72, "state") == "Open") and (os.time() - deviceLastModification0) >= 900) then
delayedCheck0 = true;
The "value" parameter should be "state". The controller doesn't have a base property called "value" so the fibaro:get() function returns nulls. After that the whole scene falls over.
Cheers
