anders.malmgren 0
Hi. I have a Switch 2 thats not connected to any load. I want to use it as a remote and control a Dimmer 2 (I cant understand why fibero does not have a binary Switch without relay). I have sort of gotten it to work but not 100%.
I have set group 2 (S1 on / off) and 3 (S1 dimmer) on the switch and associated it with the Dimmer 2. I have also change Parameter 20 to 0 (momentary switch).
I can turn on and off the Dimmer this way, if I double click the dimmer goes to 100%. I can also dim up by holding the button. But when I relase and hold again it does not dim down, instead it dims up.
I guess I need to change some other paramters in the Switch 2 but I do not know which ones.
I'm on a Vera plus controller btw.
edit: One thing, the dimmer 2 device options are empty. While the Switch 2 has all its parameters visible, is this correct?
Edited by anders.malmgren2 answers to this question
