PeCe 0
I have a problem when linking my heat controller to window sensor. What I want to achieve is that despite of schedules, when the window in the room gets opened, the heat controller should close the valve. When the window is open again, it should return to the normal operating mode.
Both the heater and window sensor are linked to the same room. Both up to date regarding software version.
I can see a read only parameter 'Opened window detected' but it never gets set.
Can you help me and point me out what has to be set to make it work like 'smart home' should?
Regards
PeCe
5 answers to this question
