wall plug can not keep off
Guest passagne
Hi everybody,
i'm french new member and i have a problem with wall plug.
I 'm not be able to keep it off.
even if light is offn after press button B, the wall plug is always on.
An idea ?
@passagne there is a setting, check parameter 1
Guest passagne
    no, param 1 =0
    i think the plug is out
    i hear the relay when i put plug on but i cant hear when i put off.
    try to remove the plug and add it again.
    then test:
    if plug goes on/off with button on the plug, if it doesn't it's defect.
