MichaelH 0
Hi, I have installed an fgs223 as a toggle switch with 2 other wall switches and electrically does everything work fine.
In Homeassistant via ZWAVE I can also Control the switch.
But in Homeassistant it Shows its 2 channels seperatly.
If i toggle the fgs223 with the direct connected wall switch the 2 channels toggle both: one on, one off
For toggleing by homeassistant I have to toggle each channel seperately, here they are not connected.
Is there a Parameter Config set known, that the double switch Shows up in Homeassistant an 1 switch and not seperated in 2 channels?
