  • 3
Lua script for Motion sensor and auto light
Hello, can somebody share a script for auto turn on lights when motion sensor breaks and keeps on during motion detected? And lux setting also.
i have a script currently buy some time happen to crash.
thanks
Hi
@Wegerhoff thanks for sharing. I like the idea. Did u tried it on practice? I mean, is there a chance for the light to remain ON when it should be turned OFF already? (like bad signal etc etc)
more than 1y - like a charm
proof
@10der I was curious about the association solution. The scene solution works fine for sure (but I suspect starting scenes may cuase  503 or lethal death of the STM controller of HCL). Facing this pretty much often last monthes.
Yes, 503 was occupied two times this month and once when I was in work trip in Kharkiv...:(
Edited by 10der
Using this with 5 motion sensors. Lights is always switched off like it should be.
Another advantage: Associations work without HC2, means still working when HC2 is missing or crashes.
    Confirm, work great but i use LUA code, has many options.
    I buy from aliexpress a smart gsm socket, in case of failure just give a sms and reset.
    Also you can use gsm relay, but socket is easy to install just put sim inside and plug hc2.
    I use also for server and router, has 3 plugs.
    Edited by MDC
    Omg, yes! I have SonOff (~10$) and yes we can cut power and back again
    but! sometimes HC2 booting  to recovery mode and stay here while user press continue button...
    On 11/18/2018 at 8:41 AM, 10der said:
    some comments here
    you may schedule lights (and level light) by weekday also.
    for example, I am a Jew, for example,:) I have on Friday for Shabbat. :)
    so,
    Mo-Th from 18:00 till 6 morning
    Fr and Sat from Sunset till 23:35
    and Su back to normal
    if you do not want to control lights by LUX simple make Ids is empty
    if you wanna control lights by many motions simple add Ids by a comma
    if you wanna  lights many lights simple add Ids by a comma
    quick update.
    now you may control all lights in house via single scene
    I find something i'm not sure if it' a feature or a bug in your code.
    I have module ID 100 for example and set your code to turn light on between sunset and sunrise, it's work like a charm, BUT, i if i'm before sunset and try to turn on light from switch of fibaro app, your code auto turn it off. So i deduce that code let that ID 100 that i set for to be on only in interval mentioned above. In rest turn it off.
    Same whit lux level, if i set level to 50 and lux sensor is below 50 i can turn on by app/ switch and also turn on on movement, but if lux go above 50 an i try to turn on, will turn off in 1 second.
    no manual checks.developed.
    ok. I can provide my full script here.
     you lose me here:)) it's to complex
    Can be done to check if manual operated to bypass auto?
    Edited by MDC
    PS:
    door_ignore - if you use a sensor is a door sensor and you forgot to close the door - can ignore this fact.:)
    exclusion - no light if some devices in this array if "on". for example you have a big room with lighting (deviceId 123) and backside light lamp triggering by motion (deviceId 321)  so, if 123 is lighting no needing turn on the single lamp by motion.
    exclusion = { 123  }
    timeout_manual - if set then can be used as timeout when user turn light by a switch (or app) manually otherwise used default timeout
    manual = true - no sensors at all. just check timeout when user turn device manually
        Fence = {
            name = "sddsds",
            sensors = {},
            powers = {679},
            timeout = 60 * 30,
            manual = true
    about
    Bathroom_WC = {
           name = "WC - ground floor",
            sensors = {891, 732},
            powers = {1094},
            door_ignore = true,
            timeout = 60 * 5,
            times = {
                ["$Sunset..$SunriseTwilight"] = {
                    timeout = 60 * 15
    I used two sensors here
    732 - its door sensor
    891 - motion sensor
    door_ignore = true - cuz my wife forget to close the door... without this param lighting will wait for closing the door!
    timeout = default timeout, so if you turning light on at the day it turned off after 5 min
    times - no comments
    why timeout again? it's overriding. so, in the evening and the night timeout = 15 min.
    also, for example, you may any others override params. for example, timeout_manual... and if you turn on at the night manually script turned off after a this period...
    about predefined values.
    you can use on;y $Sunset and $Sunrise. also use can add or sub minutes.
    times = "$Sunset-15..$Sunrise+15"
    also you can use own any predefined values (string in time format HH:MM) but you must init this values via global values panel and keep it actually.
    for example
    you create global value "Night" set value 23:00
    now you can use it in script
    times = "$Sunset-15..$Night"
    Edited by 10der
    Hi Folks,
    @10der I really need your help. Your first script looks to be a PERFECT solution for me and I have been struggling with my bath light for weeks! Honestly I'm close to throw HC2 out of the window. so... I used your script and nothing is turning on...  I just have this message
    What I have done wrong?
    Begging for help :)
    1 hour ago, TripleZulu said:
    Hi Folks,
    Begging for help :)
    1) I have updated script you script is old
    2) please fix my bug find min_lux and change tp dev.min_lux
    2 hours ago, TripleZulu said:
    Hi Folks,
    Begging for help :)
    Can you give use more details for NEST ?
    You have a lua script, plugin....
    Dear 10der.
    First of all, thanks for prompt replay.... but it's still not working
    Now I have this [DEBUG] 16:25:04: 2018-11-23 16:25:04.483997 [ fatal] Unknown exception: /opt/fibaro/scenes/63.lua:197: attempt to compare number with nil
    Here is the entire code :
    %% autostart
    %% properties
    %% weather
    %% events
    %% globals
    local lighting = {
        Bathroom_WC = {
            -- timeout in minutes
            timeout = 15,
            -- motion sensors IDs
            sensors = {
                95
            -- luxs IDs
            luxs = {
                97
            -- lights IDs
            lights = {
                -- 941
                57,181,190
            -- minumum lux for lighting
            min_lux = 20,
            -- when
            time_interval = "13:00..06:00",
            -- from dusk till dawn
            --time_interval = "$Sunset-15..$Sunrise+10"
            -- for dimmers + time
            --time_interval = {
            --    ["18:00..06:00"] = 99,
            --    ["06:00..18:00"] = 20
            -- for dimmer you can set default level here
           -- light_level = 99
        Another_room = {
            -- own params here
    if require then
        require("fibaro")
    local function between(timestr)
        local dayMap = {
            ["1"] = 1,
            ["2"] = 2,
            ["3"] = 3,
            ["4"] = 4,
            ["5"] = 5,
            ["6"] = 6,
            ["7"] = 7
        local smap = {
            ["Sunset"] = "sunsetHour",
            ["Sunrise"] = "sunriseHour",
            ["Evening"] = "sunsetHour",
            ["Morning"] = "sunriseHour"
        local function trim(s)
            return (string.gsub(s, "^%s*(.-)%s*$", "%1"))
        local function offset(s, o, p)
            if (not (o and p)) or o == "" then
                return s
            local h, m = s:match("(%d+):(%d+)")
            local t = 60 * h + m + (o == "+" and p or -tonumber(p))
            return string.format("%02d:%02d", math.floor(t / 60), t % 60)
        local function sec2hmStr(hms)
            local h, m, s = math.floor(hms / 3600), math.floor((hms % 3600) / 60), hms % 60
            return string.format("%02d:%02d", h, m)
        local function betw(interv)
            local dt, start, stop = os.date("*t"), interv:match("^([%S%a0-9%.%:]+) ?(.*)")
            stop = stop == "" and start or stop
            local d1, h1, m1 = start:match("^([%S%a%.]-)%.?(%d+):(%d+)$")
            local d2, h2, m2 = stop:match("^([%S%a]-)%.?(%d+):(%d+)$")
            d1 = d1 == "" and (dt.wday == 1 and 7 or dt.wday - 1) or dayMap[d1]
            d2 = d2 == "" and d1 or dayMap[d2]
            local d = dt.wday == 1 and 7 or dt.wday - 1
            if not (d >= d1 and d <= d2) then
                return false
            m1, m2, t = h1 * 60 + m1, h2 * 60 + m2, dt.hour * 60 + dt.min
            if (m1 <= m2) then
                return m1 <= t and t <= m2 -- 01:00-02:00
            else
                return m1 <= t or t <= m2 -- 23:00-21:00
        timestr =
            timestr:gsub(
            "$(%w+)([%+%-]?)(%d*)",
            function(s, o, p)
                return offset(smap and fibaro:getValue(1, smap) or fibaro:getGlobal(s), o, p)
        for _, interv in ipairs(split(timestr, ",")) do
            if betw(trim(string.gsub(interv, "%.%.", " "))) then
                return true
        return false
    local function inArray(needle, haystack)
        for i, n in ipairs(haystack) do
            if (tonumber(needle) == tonumber(n)) then
                return true
        return false
    local function getLux(dev)
        local totalLux = 0
        local averigeLux = 0
        if #dev.luxs > 0 then
            for i = 1, #dev.luxs do
                totalLux = totalLux + tonumber(fibaro:getValue(dev.luxs, "value"))
            averigeLux = math.floor(totalLux / #dev.luxs)
        else
            averigeLux = 1000
        return averigeLux
    local function getMotionStatus(dev)
        if dev.sensors then
            for i, n in ipairs(dev.sensors) do
                if (tonumber(fibaro:getValue(n, "value")) > 0) then
                    return 1
            return 0
        else
            return 0
    local function getLastBreach(dev)
        local breach = 0
        if dev.sensors then
                local value = tonumber(fibaro:getValue(n, "lastBreached"))
                if (value > breach) then
                    breach = value
        return breach
    local function getLlght(dev)
        if dev.lights then
            for i, n in ipairs(dev.lights) do
                local value = tonumber(fibaro:getValue(n, "value"))
                if (value > 0) then
                    return value
        return 0
    local function setLlght(dev, value)
            local lightType = fibaro:getType(n)
            if (lightType == "com.fibaro.multilevelSwitch" or lightType == "com.fibaro.FGD212") then
                -- dimmer
                fibaro:call(n, "setValue", value)
            elseif (lightType == "com.fibaro.FGRGBW441M") then
                -- RGBW
                -- TDOD:
                local r, g, b, w = 0, 0, 0, 255
                fibaro:call(n, "setColor", r, g, b, w)
            else
                -- switch
                if value > 0 then                <------- line 197
                    fibaro:call(n, "turnOn")
                else
                    fibaro:call(n, "turnOff")
    local function isTime(dev)
        if dev.time_interval then
            if type(dev.time_interval) == "table" then
                for k, v in pairs(dev.time_interval) do
                    if between(k) then
                        dev.light_level = v
                        return true
                return false
            else
                return between(dev.time_interval)
        else
            return true
    while true do
        for k, dev in pairs(lighting) do
            if isTime(dev) and getMotionStatus(dev) > 0 then
                local lux = getLux(dev)
                if lux < dev.min_lux then
                    if getLlght(dev) == 0 then
                        setLlght(dev, light_level)
            else
                if os.time() - getLastBreach(dev) > 60 * (dev.timeout or 60) then
                    if getLlght(dev) > 0 then
                        setLlght(dev, 0)
        fibaro:sleep(1000)
    5
    I've found the lua code somwhere in the net. I guess it was
    Does NOT work as I expected! but.... I'm a newbie so maybe I did something wrong.
    I can send you the lua but I guess you will find on his website more explanation.
    6 minutes ago, TripleZulu said:
    • Please login or register to see this link.
    Dear 10der.
    %% autostart
    %% properties
    %% weather
    %% events
    %% globals
    local lighting = {
        Bathroom_WC = {
            timeout = 15,
            sensors = {
                95
            -- luxs IDs
            luxs = {
                97
            -- lights IDs
            lights = {
                -- 941
                57,181,190
            min_lux = 20,
            -- when
            --time_interval = {
           -- light_level = 99
        Another_room = {
            -- own params here
    if require then
        require("fibaro")
        local dayMap = {
            ["1"] = 1,
            ["2"] = 2,
            ["3"] = 3,
            ["4"] = 4,
            ["5"] = 5,
            ["6"] = 6,
            ["7"] = 7
        local smap = {
                return s
                return false
            if (m1 <= m2) then
            else
        timestr =
            timestr:gsub(
            function(s, o, p)
                return true
        return false
                return true
        return false
        local totalLux = 0
        else
            averigeLux = 1000
        return averigeLux
        if dev.sensors then
                    return 1
            return 0
        else
            return 0
        local breach = 0
        if dev.sensors then
                    breach = value
        return breach
        if dev.lights then
                if (value > 0) then
                    return value
        return 0
                -- dimmer
                -- RGBW
                -- TDOD:
            else
                -- switch
                else
                    if between(k) then
                        dev.light_level = v
                        return true
                return false
            else
        else
            return true
    while true do
            else
                        setLlght(dev, 0)
        fibaro:sleep(1000)
    Please share whit us.
    not a problem :)
    as I remember correctly you have to create variable temp first and token from IFTTT
    %% properties
    %% events
    %% globals
    temp
    local param1 = fibaro:getGlobal("temp")
    local key = “Yb2P3z**************zVCKE”  < ----  your token from ifttt
    local event = 'temp'
    local url = 'https://maker.ifttt.com/trigger/'..event..'/with/key/'..key..'?value1='..param1
    print (url)
    local http = net.HTTPClient()
      http:request(url, {
          success = function(resp)
            if resp.status == 200 then
              fibaro:debug(resp.status)
            else
    @MDC ok. I'll create a new post with clear script!
    Thank you soooo much !!  Дуже дякую
    Link please
