julesmartens 0
I'm no fan of the build-in alarm in HC2 so I'd like to create my own scenes/VD's for this. .
@Sankotronic is working on a very promising UHAS system but his plans are pushed out (no offence, he released real nice things already, I'm fan)
so I decided to move on, writing some code myself with hopefully some help of you ;-)!
What do I use in my alarm;
> Lights (selected regular lights in the house to switch to 100% when alarm is breached)
> Door/window sensors
> PIRs
> Sirenes (for acoustic alarm)
> flashlight (for visual alarm)
> RGBW led indicator (at the entrances to notify alarm is; just armed (leave the house indicator), armed (not safe to enter indicator), disarmed(safe to enter indicator)
What do I want;
> Fibaro remote keychains available to manually arm/disarm the alarm
> All users have a IFTTT account on their phones to trigger a scene when entering/leaving home (geofence). This will set my global "guestmode". (bad exerience with Fibaro GPS)
> When nobody is at home, the global "alarmmode" should set to "FullAlarm". At "FullAlarm" all PIRs and D/W's sensors are set to armed. (report error when not in safe state when arming).
> When at night (Darkness) all users are at home and all PIR and D/W are safe for X time, "sleepstate" to be set "sleep" else "awake".
> when at sleep, the "alarmmode" will switch to RingOnly. Only the D/W sensors will be armed (not PIR). When a PIR is breached the alarmmode will be set to disarmed state. When sleep state is reached again the alarmmode will switch back to RingOnly.
> if armed and breached, the alarm is triggered. The sirenes and flashlight will start to run and all lights will be set to 100%. If all D/W and PIR are safe for X time, alarm to back to armed state and lights off.
> if armed and breached, the timestamp of alarm will be logged. If alarm is disarmed after it was breached the notification LED will warn for this.
> If I disarm the alarm, put all lights/DW in safe state.
> Notifications via Pushover or even better, use the message hub of @autofrank with Fibaro PopUps and Push services. Unfortunately I currently have errors with the message hub.
What is my current status. All code based on simple if/then LUA coding, no fancy loops.
DONE: scene to check all PIRs Scene will set global variable
DONE: scene to check D/W sensors. Scene will set global variable
DONE: One scene to take care of the global sleepstate
DONE: One scene to take care of the global guestmode
DONE: a VD to manually set alarmstate and alarmmode.
DONE: a VD to manually set guestmode
todo: a mainalarm scene to arm/disarm the alarm (based on above algorithm)
todo: an alarm scene to trigger the alarm when breached (or merge this in the mainalarm scene)
todo: scene(s) for RGBW led indicators
todo: scene(s) for the push notifications (Alarm breached, error (Eg door/window open when arming the alarm)
I noticed that I get stuck with the remaining scenes. I'm no programmer, so I use mainly simple if/then LUA code. With a lot of scenes in the alarm you easily get lost.
In an attempt to keep my coding cleaner/more condensed I want to use tables/json. I already use the Hometable but that's just a simple copy the instructions of @AutoFrank.
Questions;
For the remaining alarm scenes I have difficulties how to store a table in a global and even more how to use from a table. The tutorials on this topic are not clear to me yet.
For example, when the alarm is breached, how to switch all lights to 100% for the device IDs in a global(table). I have seen examples of code like k,v in (i)pairs but I don't get it yet.
Can somebody help me with some code examples?
Any other suggestions on my ideas for an alarm?
Thanks!
Jules
Link to post
