sir_horn 2
I have a setup with two HC2. Unfortunately my master HC2 freezes sometimes which causes problems with our heating, alarms etc, especially when we are not home to see this. When we are away we cannot do the button restart which is required to get it up n running again. I will continue to work on that problem with Fibaro suport but have put sooo many hours on it without any success so must try another approach paralelly.
Since we have two HC2 I thought that they could watch over each other and restart the other, via a Fibaro wall plug, if its non responsive.
Any ideas on how they surveillance could be done? My ideas is to set up a scene with a query sent every 3 minutes and if there is no answer it asks the wall plug to turn off, wait a minute and then turn on again (alos send a notification about the restart). But I cant code
This will also help me to get closer to the main problem with freezing
