Music
Is there a way to play a music file (lke mp3) or a spotify playlist, on the Google Home triggered by a scene on HC2 ?
That’s a great question — integrating Spotify or local MP3 playback with Google Home through HC2 can be a bit tricky. Google tends to keep playback pretty locked down within its ecosystem, so triggering a playlist directly via a scene isn’t always straightforward.
One workaround is to use Google routines or automation tools like IFTTT to trigger playback, though you might find it limited if you want to play local files instead of streaming.
If you’re trying to play your own music files or Spotify playlists offline, you might want to check out DumpMedia Any Music Converter. It lets you convert Spotify tracks into MP3 or other formats that you can easily store and play from local devices — including setups connected to Google Home. It’s a handy solution if you want more control over your playlists without relying completely on streaming.
@T.Konopka
"hidden spammer"
