mephist0 1
I have some problem with my heating panel and i do not find the usage of "none" temp explained anywhere.
I guess its better explained with a screenshot. See below.. My problem is that i have a temp sensor in my garage that is paired with a wall plug connected to a space heater in my garage. This i try to control via a heating panel.
01:00-05:00 the temp is set to 6c all the other times it is set to "none"
At 01:00 the wall plug is switched on and starts heating when it reaches 6c the wall plug is switched off.. All good so far. Before 05:00 the wall plug was switched on again. The time passed 05:00 and the wallplug is still switched on and never switched off again until i noticed this at 10:30 and turned the wallplug off. The temp was then 10c.
So.. My question is, what is "none" referring to? I thought it was "do not heat" during these times? Can't i use the heating panel in this way?
And yes, i know that the temp sensor is too close to the heating source as you can see in the temp chart.. I will fix that when i got it to work correctly
