Suspicious login attempts
After upgrade to 4.520 I have received four email with suspicious login attempts from ip 34.244.43.224 and says that login is blocked for 30 minutes. I have HCL and in the email appear a logo from HC2.
anyone receiving this email?
Yes with IFTTT calls...
Hi
I am also receiving such e-mails around once a month but the IP address is different and I don't know what it is ?! Is someone really wants to hack into my HC2 ?!?
Hi ! I have the same but it's not due to 4.520, unfortunately I have this issue since several weeks and it's alway coming from an IP based in Ireland on amazon servers.I've check last one and localisation/servers have changed...
In the french forum several peoples have raised the same issue, we have compared the IP and it's still the same.
I would like to had that some people highlighting the problem doesn't have any alexa devices, no open ports ... so that one could be exclude.
I spent to much time before advising and yo've been faster then I, so thank @NunoMartins !
@I.Srodka does it make sens for your to escalate this issue ? thank you for your help  !
For info I've checked my mailbox (didn't check my spams yet) and I can find exactly 46 tentatives starting in
Edited by Tony270570
Hi!
Could you (and everyone involved) provide details about your plugins and virtual devices?
It would help us investigate it further.
Yep I've been getting them often too now.
The IPs that have tried mine are:
52.214.70.130
34.241.63.69
34.241.63.69 again
Any ideas?
Exactly the same:
52.214.70.130
34.241.63.69 (three times)
Edited by Alex
Me too.
I Think it started after I merged google assistant with fibaro.
I get a mail every 30 minutes...
Edited by Baloba
hi
I've got :
- ifttt, google home and alexa  accounts
-pluggins : the default ones , yr weather (default ?) + Hue, netatmo , fibaro intercom that's it.
Thank you very much for your help !
 Hi, I was thinking the same, but some people I talked with in the french forum don't have any google or alexa devices. but you're right,  it must remains an axe of investigation.
He,
Yes, also the same here after the integration of google home.
IP; 34.241.63.69
Guest Turmoil
Me too! IP 34.241.63.69. I have HC2 (just installed 4.520) with Google Home and IFTTT integration.
Is this an exposure in "Fibaro Id" processing or is Google and/or IFTTT mixing up users (would not be the first time)?
Two times today and one yesterday from 34.241.63.69, and several times from 52.214.70.130 some time ago. Otherwise a mail approx once a month or so before yesterday.
It's possible it started when I connected Google Home with Fibaro...
Only standard plugins, Yr weather.
Is that coming from Fibaros remote login solution? I cannot login into the web GUI remotely now... So it would mean that the system is actually blocking the same IP as remote connection is coming from.
Dear Fibaro Support,
I have had numerous of the suspicious login attempts during the last few weeks from:
52.214.70.130
34.241.63.69
They both track back to AWS EC2 instances in Ireland.
My HC2 is running 4.510
Plugins:
DSC Alarm
Envisalink Alarm
HEOS Denon
HIKvision Ds2cd21
Modular Alarm
Samsung TV
Satel Alarm
YrWeather
Virtual devices:
VoiceAlertF9E8
MS checker v2
It would be helpful if Fibaro Support could provide some advice re these suspicious login attempts.
I have the same issue...using, Google home and IFTTT
Suspicious Login Attempts Prevented
We noticed 5 failed login attempts to your HC2-048748 that seemed suspicious.
For your security, the following IP address: 34.241.63.69 has been locked for 30 minutes.
I have disabled IFTTT now and check if I get any more mails.
Idon't think that it is because of Google (Google won't use any AWS server I guess ;) , but I might be wrong).
    I use ifttt and yahoo weather plugin.
    ifttt is configured since 4.170.
    yahoo weather since 4.520 because the default plugin not works!
    I also have Security Alert messages with the topic "Suspicious Login Attempts Prevented".
    I use following extension (HC2 v4.510):
    -pluggins : the default ones , netatmo, sonos, sony TV
    The first attemt was 20/11/2018 (11:00) from IP address: 52.214.70.130,
    after were:
    23/11/2018 (22:42) from IP address: 52.214.70.130
    - 29/11/2018  three times (12:50, 13:27, 14:05) from IP address: 34.241.63.69
    30/11/2018 two times (13:28, 14:05) from IP address: 34.255.120.42
    21/11/2018 I updated SW to version 4.5.10, all external accounts was connected earlier.
    As to date 23/11 not sure, maybe it was my attempts to rescan devices/scenes from google home or alexa app, but for 29 and 30 no ideas, during the day I didn't do any personal actions with HC2.
    After disabling all IFTTT s I did not get any more mails so far.
    (Also the IFTTT haven't been used while I got the mails)
    Guest Turmoil
    I backed-up then deleted my IFTTT account 5 days ago (only some tests at this stage). Since then the daily security alerts have stopped.
    I also had error messages from different addresses.
    But what is more worrying is that the local address' 192.168.0.xxx) of my PC generated the same message. But also in the same time my ip adresse from my internet router.
    Since I can not access my HC2 for 30 minutes. I hope it will work after 30 minutes.
    It is imperative that you find the origin of this problem. It becomes very disturbing.
    Edited by MAM78
    It's a disaster, I can not access my HC2 anymore. Each time he tells me that my login and password are wrong and that I have more than 4 attempts before blocking for 30 Min.
    Same if I access from Fibaro ID. I also tried to connect by my sharing the connection from my cellphone so as not to go through my internet router. But it's the same.
    But my HC2 continues to work. I have not dared for the moment to restart it.
    You would not have an idea of what's going on?
