Guest Turmoil
I installed the fgs-223 about two weeks ago and it associated with my HC2 no problem. I have used the physical switch and used scenes to manage the lights on the switch for the past two weeks. This evening the lights were not turned on via a scene but did still work from the physical switch. On further investigation the switch controller and the two switch devices have just disappeared from the HC2 configuration. During install when I turned the power off they appeared as dead nodes but now they do not exist at all and power has not been lost in any case.
Has anyone experienced this problem? Are there any diagnostics I can use to determine what might have happened? Are there any alternatives to re-associating the device?
Thanks in advance for any help you can give.
