very little info on setup.
Rain delay - i assume when set it works through global values so when yahoo weather senses rain it automatically applies the delay. ?. If not is there some La to enable this?.
Adjust water - what does this actually do?.
Lua code to setup to be able to extend the control panel to a mobile device.
Rain delay - not linked to anything. You have to set it manually or via the LUA scene with any type of trigger (including yahoo weather). I will try to find the code for this later today.
Adjust water - makes your watering cycle longer or shorter by defined %.
" to "
Temat został przeniesiony z "
" do "
