skywalker 18
I have installed an FGS-223 double switch with a HC2. First switch apparently is working fine, even if I use the manual switch, the status is updated in the app.
However, for the second switch, works if I use the manual switch, works if I use the app. But when changing manually, the status is not modified in the app (so turning the lights when not at home turns to be difficult). So even if I turn on a light from the physical switch, in the app I see it as OFF.
Does anybody have any idea what's the problem? I looked into the topics, search the manual - could not find a solution.
One additional question: when added to the z-wave network, this double switch appeared as three items, I left it to unassigned not to confuse the use of the actual two. Can I have only the two which actually exist?
Thank you in advance for any help you may provide to a newcomer
4 answers to this question
