Can't change buttons now on KeyFob
hugosauren
I can't change the buttons on the KeyFob now after the initial setup :/
I tried to add a hidden scene manually (deleted the old button then added a new one) but it didn't work either.
I want to have the same options that I had from the beginning, where I could on the KeyFob device change the buttons, can anyone help me please?
Why don't you use a lua scene for the key fob?
After:
Then
fibaro:debug('key')
You put as bellow:
if(tonumber(fibaro:getValue(ID lamp, "value")) >= 1)
then
 fibaro:call(ID lamp, "turnOff")
else
then
fibaro:call(ID lamp, "turnOn")
as below is the lua code.
%% properties
%% events
593 CentralSceneEvent
%% globals
local sa = fibaro:getSourceTrigger()["event"]["data"]
--fibaro:debug(json.encode(sa))
-- button square
if ((sa['keyId'] == 1) and (sa['keyAttribute'] ==  'Pressed'))
  then
  fibaro:debug('key1')
if ((sa['keyId'] == 1) and (sa['keyAttribute'] ==  'Pressed2'))
  then
  fibaro:debug('key1 double')
if ((sa['keyId'] == 1) and (sa['keyAttribute'] ==  'Pressed3'))
  then
  fibaro:debug('key1 triple')
if ((sa['keyId'] == 1) and (sa['keyAttribute'] ==  'HeldDown'))
  then
  fibaro:debug('key1 held')
if ((sa['keyId'] == 1) and (sa['keyAttribute'] ==  'Released'))
  then
  fibaro:debug('key1 release')
-- button circle
if ((sa['keyId'] == 2) and (sa['keyAttribute'] ==  'Pressed'))
  then
  fibaro:debug('key2')
if ((sa['keyId'] == 2) and (sa['keyAttribute'] ==  'Pressed2'))
  then
  fibaro:debug('key2 double')
if ((sa['keyId'] == 2) and (sa['keyAttribute'] ==  'Pressed3'))
  then
  fibaro:debug('key2 triple')
if ((sa['keyId'] == 2) and (sa['keyAttribute'] ==  'HeldDown'))
  then
  fibaro:debug('key2 held')
if ((sa['keyId'] == 2) and (sa['keyAttribute'] ==  'Released'))
  then
  fibaro:debug('key2 release')
-- button cross
if ((sa['keyId'] == 3) and (sa['keyAttribute'] ==  'Pressed'))
  then
  fibaro:debug('key3')
if ((sa['keyId'] == 3) and (sa['keyAttribute'] ==  'Pressed2'))
  then
  fibaro:debug('key3 double')
if ((sa['keyId'] == 3) and (sa['keyAttribute'] ==  'Pressed3'))
  then
  fibaro:debug('key3 triple')
if ((sa['keyId'] == 3) and (sa['keyAttribute'] ==  'HeldDown'))
  then
  fibaro:debug('key3 held')
if ((sa['keyId'] == 3) and (sa['keyAttribute'] ==  'Released'))
  then
  fibaro:debug('key3 release')
-- button triangle
if ((sa['keyId'] == 4) and (sa['keyAttribute'] ==  'Pressed'))
  then
  fibaro:debug('key4')
if ((sa['keyId'] == 4) and (sa['keyAttribute'] ==  'Pressed2'))
  then
  fibaro:debug('key4 double')
if ((sa['keyId'] == 4) and (sa['keyAttribute'] ==  'Pressed3'))
  then
  fibaro:debug('key4 triple')
if ((sa['keyId'] == 4) and (sa['keyAttribute'] ==  'HeldDown'))
  then
  fibaro:debug('key4 held')
if ((sa['keyId'] == 4) and (sa['keyAttribute'] ==  'Released'))
  then
  fibaro:debug('key4 release')
-- button minus
if ((sa['keyId'] == 5) and (sa['keyAttribute'] ==  'Pressed'))
  then
  fibaro:debug('key5')
if ((sa['keyId'] == 5) and (sa['keyAttribute'] ==  'Pressed2'))
  then
  fibaro:debug('key5 double')
if ((sa['keyId'] == 5) and (sa['keyAttribute'] ==  'Pressed3'))
  then
  fibaro:debug('key5 triple')
if ((sa['keyId'] == 5) and (sa['keyAttribute'] ==  'HeldDown'))
  then
  fibaro:debug('key5 held')
if ((sa['keyId'] == 5) and (sa['keyAttribute'] ==  'Released'))
  then
  fibaro:debug('key5 release')
-- button plus
if ((sa['keyId'] == 6) and (sa['keyAttribute'] ==  'Pressed'))
  then
  fibaro:debug('key6')
if ((sa['keyId'] == 6) and (sa['keyAttribute'] ==  'Pressed2'))
  then
  fibaro:debug('key6 double')
if ((sa['keyId'] == 6) and (sa['keyAttribute'] ==  'Pressed3'))
  then
  fibaro:debug('key6 triple')
if ((sa['keyId'] == 6) and (sa['keyAttribute'] ==  'HeldDown'))
  then
  fibaro:debug('key6 held')
if ((sa['keyId'] == 6) and (sa['keyAttribute'] ==  'Released'))
  then
  fibaro:debug('key6 release')
-- combinatie van verschillende knoppen
if (sa['keyId'] == 7)
  then
  fibaro:debug('key7')
  fibaro:call(22, "turnOn")
  if (sa['keyId'] == 8)
  then
  fibaro:debug('key8')
  fibaro:call(22, "turnOff")
if (sa['keyId'] == 9)
  then
  fibaro:debug('key9')
  if (sa['keyId'] == 10)
  then
  fibaro:debug('key10')
if (sa['keyId'] == 11)
  then
  fibaro:debug('key11')
  if (sa['keyId'] == 12)
  then
  fibaro:debug('key12')
