Mdh 0
I have just installed a FGT-001, and the Valve doesn't close even though the heat is turned off (White mode).
If I remove it from the radiator I can see it is fully open. Sometimes I can hear the motor spinning, but I goes back to the same position again…fully open!!!
Have anyone experienced that or have a solution for it? Any help is appreciated.
(It is connected to an external temperature sensor FGBRS-001)
