FGR222 and position in zwave
Olosi
  Have installed a roller shutter 2 to my blind, inclusion was ok but calibration a little weird since if I started it with the blind fully closed the motor went only up and down, while if I start the calibration from blind fully opened it does the full cycle but reversed indeed (not up down up but down up and down).. this results in having the wrong position on the z-wave hub.
The hub shows fully opened when it is closed and vice-versa..
When I push the buttons on the wall it moves correctly down, goes down and up goes up...
Could it be  a wrong wiring ? if not any advice ?
Yes, it should (must) do the calibration in the order described. If it does that in reverse, then please swap the outputs.
Then see if the switch goes in the right direction, you may have to swap those wires too.
Which hub? On a HomeCenter "Up" should mean "Up".
On other controllers, this is not always the case.I know how to fix that on "Home Assistant" but not on other controllers.
That "cover.fibaro_ ..." string is the entity id of your FGR222.
Edited by petergebruers
  • Thank you very much... had to change all the 4 wires Q1,Q2,S1,S2 recalibrated and voilà everything is perfect now !
