knuth 29
Task:
To control one channel on the RGBW controller/dimmer remotely through a double momentary switch (using S2) on the Dimmer 2.
Solution, and some questions:
First question: Group 5 is specifically for a multilevel switch, e.g. a dimmer. Why is there even an S box available for this group? Should it ever be used?
Second question: There is a box for the HC2 at the top of the Associations list. What is the effect of ticking this box? Should the HC2 normally be ticked in the M column as well?
Third question: I have seen a screen dump somewhere for a similar case. Here, the Dimmer itself was ticked in the associations list. I have avoided this, as it does not seem logical to include an association from a unit to itself. Any views?
Fourth question: I assume that using Group 5 transfers all the normal switch commands: Single click for on/off, click and hold to dim up or down, double click for full light. Correct?
Fifth question: In step 3 above, would it be possible (or even preferable) to select the slave unit used to operate the dimmer function instead?
The reason I ask these questions, is that I have successfully followed the 6 steps above, with slight variations, and get variable results. Some units seem to work seamlessly, others are a little erratic (no response on single click, hard to control dimming function etc.). The 'slight variations' are in the way I did the associations, and are related to some of my questions. If anybody can provide suggested answers, I can focus on any remaining issues.
4 answers to this question
