RING DOORBELL by RING.COM
before:
create two global vars, please
"RingToken" - used by the script internally
"Doorbell" - for user actions.
0 - nothing
1 - motion detected
2 - ding-dong
happy using!
Edited by 10der
Oh Dear ... ran for a while and then "[DEBUG] 20:32:15: 2019-02-18 20:32:15.136868 [ fatal] I/O error: End of file" when a motion occurred.
Same here. Ran for 15 mins
Then same error.
    Fibaro can't catch 401 in https mode and throw an exception. :(
    it's not good but we can decrease
    from local tokenRefreshTime = 60 * 50 to  local tokenRefreshTime = 60 * 15
    It's a pitty that " [ fatal] I/O error: End of file" still occures and the script stops.
    Even if there is no motion. Tried different tokenRefreshTime values.
    actually ring,com API sent to client 401 as signal what we need to re-login / get a new token
    unfortunately, FIBARO https core can't handle this and throw  [ fatal] I/O error: End of file" ]
    btw. big facepalm here also, what I hope on xpcall
    what should handle any exception here.
    I'm having issues with my
    can anyone help?
    Ring is deep trouble issue by default ;)
    I curse the day when I bought ring.
    I had troubles with authentication, got a credentials error. The credentials were correct. Password was the issue (special characters). I changed the oAuth function like this:
    Maybe you can include it in your code
    ring change with again. if honestly I am stop using ring. ring - it was my Big mistake.
    I bought new ring v3
    and i found your Lua script to connect my new ring to HC2
    But i have an error
    Can you help me to solve it?
    Thank
    ring now works with OTP token.
    LUA script not udapted for it. alas
    @[email protected]please remove your email from nick... spammers aren't sleeping.
    @10der
    Yes, you're right, thank for your advice
    but i can't put an alias.
    My account is created and link with my @fibaro account, and i didn't found, how modified my "display name"
    On 5/3/2020 at 4:25 PM, 10der said:
    Is there a fix for this as I am getting the same fatal unexpected error
    Edited by red1leader61
    +1
