    3 minutes ago, jgab said:
    What kind of error? It still seems like what you get is not what you had in your first example.
    Can you do this to print the xml data?
    1
    This is what i get i have pasted the debug for line 34  but is'nt giving me any thing to show
    /monthly_2019_02/image.png.d14c91288043c714a91d387cbff1597d.png" alt="image.png.d14c91288043c714a91d387cbff1597d.png" />
    What error message did you get on line 33 the
    line?
    line?
    see picture above that is the error it is given me  back
    this is my code  what i have right now
    Edited by pepijn
    If I copy the code in the previous post and past it into a new post (inside code tags <>), I get a little red dot just before the 'repeat' command. Try to copy the previous post onto a new post and see for yourself. These are "invisible" characters that seems to sneak into the code when copied and pasted in the forum - they don't show but gives compile error - or even worse runtime error. I have tried to clean it in the code below. Try to copy it and see if it works.
    still the same error.
    i know what you mean with the litle red dots . (which i always remove and than the code is still the same)
    But it's a compile time error (when you save the VD) or a runtime error when you run the code?
    The 'getSelfId()' seems to be related to your first line? Line numbers for error can be strange...
    it is a runtime error only when i run the code i get that error.
    (when i removed  the function from the xml than the error is gone. the text getSelfId() is not the error because that is working perfectly
    We have a mystery. If I take exactly this code and paste it into a VD button and run it
    I get this output (I don't have an IP address set)
    I think it started after a recent forum upgrade. If you look at it in HEX they'll probably show up as invalid UTF8
    I recently pasted one of my own code snippets from the forum in Zerobrane and got an error ending in:
        ... expected near '<\239>'
    \239 == 0xFE
    Otherwise this is pretty invisible. It's very annoying.
    The source of the code on my system is OK, It happens either when you paste code on the forum, or copy code from the forum to your system.
    @T.Konopka as a forum admin, would it be possible to check if the forum software could be the cause of those random invalid characters?
    Same as you with this code i have no problems ....  there is something wrong by getting the XML...   and i don't know what it is..
    but i know right now that the error I have got was because it cant find ny xml or some thing like that..
    Edited by pepijn
    @jgab  do i have to specify anything in my get command for getting an XML.
    and when i try to read more data out of the XML (with your last code) "when the XML is in a Variable"  it isn't showing.
    lets say i wanted to read out the  TYPE and Preset
    i would think i have to code it like this but it isn't showing
    Yes, you just need to add the extra formatting directives to the string.format
    So i can set now  variables to it or is it not possible like this? because now NAAM is not printed out
    locals have scope only within the for loop,  declare them before and it works.
    So, the fibaro:debug in VDs is sensitive both to strings that look like html tags and very long strings (> 1300..).
    If I do like this I can dump the xml string in the VD debug console (have to exchange '<' with '@')
    It can be useful if you want to see what you get
    oke so i have found where it is going wrong but  i dont know how i can fix it.
    The code give a error on line 35   that is : txt = txt:sub(#st+1)
    Edited by pepijn
    Good detective work! Change the debug line to this and we can see what we stumble on
    Can you also do this to log the whole xml text
    @jgab like this ?
    Edited by pepijn
    Like this
    I wil get than this :
    Ok, try this
    Two things changed - allow for both single quote and double quote as string delimiters in properties. Handles extra chars (spaces, crlf) at end of string. Hope there are no red dots...
    Support for comments
