    20 hours ago, jgab said:
    Ok, try this
    Two things changed - allow for both single quote and double quote as string delimiters in properties. Handles extra chars (spaces, crlf) at end of string. Hope there are no red dots...
    Yes! Thank you so much it works perfectly!  now the only thing i needed to do is set everything in a variable outside the function array  right?
    some thing likes this gives me a error.
    do i have to declare it before the function?
    is it possible that you give me an example for one?
    @jgab
    Edited by pepijn
    @jgab
    Can you give me an example on how i set it so variables?
    thanks
