Z Wave into wired home security system
Just Purchased Vera plus controller along with Fibaro Universal Binary Sensor and Roller shutter switches to upgrade my home automation
I would like to replace old X10 roller shutter switches with Fibaro switches.
I have a stand alone wired security system that has dry contact NO/COM/NC aux outputs that are switched upon arming and disarming the system.
I want to give Z wave functionality to it by using the Fibaro Binary sensor connected to these outputs.
The idea is to trigger a scene (closing / opening 5 shutters) when I arm or disarm the security panel
To date I have paired the UBS with Vera Plus Hub and wired IN1 on the UBS to the NO contact in the alarm panel.
Now I am not sure above the UBS configuration to achieve my goal so am looking for as much help as I can get.
At this point I haven't installed the shutter switches or created scenes
How can i tell if the UBS is functioning?
Thanks for your help
Graham Vanstan
