Aeotec ZW095 3Phase 60A Energy Meter: Parameters can't be changed
Hello
I have HC2 with the latest 4.532 beta
The Home Energy Meter seems to be on the latest firmware.
Only Total of Power in Watt an the the Total of Energy in kWH are updatet.
All of the other readings aren't updatet in HC2
I've tried to change the parameter 101 to 4144911 to have all the readings in HC2,  but in my case, it allways stays at default, which is 2. Also any other parameter can't be changed.
Below screen shots of the Aeotec Firmware, parameters, the Aeotec Parameter Calculation sheet, the Polling intervall
If I set a polling interval, in my case 30 seconds, the readings in HC2 get updatet.
Also the Aeotec ZW095 home Energy Meter doesn't show up in the actual Android Fibaro APP.
Does anybody know, how to change the aeotec parametes?
Thanks in advance
Best Regards Fabir
Hey Fabir.
I suspect this is a bug with 4.532. I cant update many of my actors either but the update problem only occurs with the actors without templates. All actors with templates can be updated.
I tested this by changing a Fibaro branded actor from Template to No Template. I can change parameters with the Template enabled but I cant change parameters without using the Template.
This is disappointing work from Fibaro, as I wasted 4-5 hours trying to get some new Goap actors working. I thought there were problems with the batch of Goap actors but then I dug further and discovered this issue.
I am going to raise a support ticket now. Maybe you should too?
GK
