Search device by IP via API [Solved]
FSE
I try to build a scene that can search by the ip address of VD and return the device id.
I have the following code just to display all the VDs that have IP but I do get nothing.... any help?
Edited by FSE
5 answers to this question
local devs = api.get('/devices')
for k,v in ipairs (devs) do
    local v2 =api.get("/devices/"..v.id)
    if v2.type == "virtual_device" and v2.properties.ip ~= "" then
        fibaro:debug((v2.name).." "..(v2.properties.ip))
IMHO you want
POST {}
  • @10der thank you sir for this answer. my concept is that I have a number of same/identical devices (for example Google Home devices) that I like to get their properties and populate them on a same table so after that I can manipulate this table.
    ARP discovery is one step further. It could be great IF HC2 had the ability to build custom wizards (wishlish), discover the devices, add to rooms, and assign custom scenes.....(I think I nailed it! :) )
