Hi all,
I'm looking for the best options for outdoor LED coloured spots / lights for use with HC2. Not looking at LED strips, specifically spots that can be directed at things such as buildings / plants.
One option I found (at least available here in the Netherlands) are lights by a company called
. However, they are controlled by their own controllers (wifi, wall mounted, app on phone, etc.) and to get them to work with HC2 seems a bit antiquated (opening of boxes, re-soldering, etc.) which I'm hoping to avoid.
Any suggestions?
I use this kind of light fixture:
Just need to take care that size of the light fixure is big enough for LED GU10 bulb since they are a bit bigger than halogen ones.
    and then prsumably you control the colour and all other settings through the Hue plugin?
    hi @Sankotronic
    where did you buy  light fixture ? could you share the link with us ?
    Hi @malitan ,
    I buy light fixtures in a local store because I wanted to be sure that HUE color GU10 bulbs will fit inside since they are a bit bigger in size than white only LED or halogen GU10 bulbs.
