Hi guys,
I am stucked can you please help me?
In below code the GV will stay on "Ochtendgloren"
Thanks in advanced for your help
%% autostart
%% properties
%% globals
local sourceTrigger = fibaro:getSourceTrigger();
if (sourceTrigger["type"] == "autostart") then
  local debug = true;
  -- check script instance count in memory
  if (tonumber(fibaro:countScenes()) > 1) then
    if debug then fibaro:debug("Script already running."); end
    fibaro:abort();
  if debug then fibaro:debug("HC2 start script at " .. os.date()); end
  while true do
    local ochtendgloren = os.date("%H:%M", os.time()+50*60)
    local gordijnopen      = os.date("%H:%M", os.time()+15*60)
    local sunrise         = fibaro:getValue(1, "sunriseHour")
    local sunset         = fibaro:getValue(1, "sunsetHour")
    local gordijndicht  =os.date("%H:%M", os.time()-50*60)
    local avondrood      = os.date("%H:%M", os.time()-50*60)
    local currentTime     = os.date("%H:%M");
    local TimeOfDay     = fibaro:getGlobal("TijdStip");
--Sunrise
    if ( ochtendgloren >= sunrise and currentTime < gordijnopen and TijdStip ~= "Ochtendgloren" )
    then
      fibaro:setGlobal("TijdStip", "Ochtendgloren");
      if debug then fibaro:debug("Ochtendgloren"); end
       if ( gordijnopen >= sunrise and currentTime < sunrise and TijdStip ~= "GordijnOpen" )
    then
      fibaro:setGlobal("TijdStip", "GordijnOpen");
      if debug then fibaro:debug("GordijnOpen"); end
--sunset
    elseif ( gordijndicht >= sunset and currentTime > sunset and TijdStip ~= "GordijnDicht" )
   then
    fibaro:setGlobal("TijdStip", "GordijnDicht");
     if debug then fibaro:debug("GordijnDicht"); end
    elseif ( avondrood >= sunset and currentTime > sunset and TijdStip ~= "Avondrood" )
    then
      fibaro:setGlobal("TijdStip", "Avondrood");
      if debug then fibaro:debug("Avondrood"); end
    fibaro:sleep(60*1000);
   else
  fibaro:debug("Script can only be run via autostart")
Ok @Sjakie,
try this:
/monthly_2019_04/image.png.8e2ca3678a8accbba43748dc12cdd19d.png" />
you can do the same with sunset and curtain closing :-D
So can you make your curtains depending on sunrise and sunset
Edited by Bodyart
    getting errorplease send complete scene
    Far from complete just added the calculation for curtain opening depending on sunrise. You need to do the same for curtain closing.....
    Edited by Bodyart
    thanks!!!!!
    gona play with it
    If this is what you want to achieve:
    /monthly_2019_04/aaa.jpg.3917ba698fc3a6516db3eb3d79465f4a.jpg" style="width:600px;height:auto;" alt="aaa.jpg.3917ba698fc3a6516db3eb3d79465f4a.jpg" />
    then try this code with defined function calculate:
    Enjoy coding!
    @Sjakie,
    did you try the code already??
    Hi @Bodyart,
    Yesterday I implemented the scene and regretely it was not working, snif, snif. This morning I started to look in to it and I must admit there where some errors in the scene. Now i hope it is okay.
    I added another day part in and it is changing the GV. I must see if he will change later on today.
    In advance I will modify all related scenes with the new names I created to avoid any interference of other GV or scenes.
    That is why I did not update you because I am still working on it.
    Thanks for your interest and support
    Hi update:
    Curtain closed at 20.32
    Lights should be off by EveningRed >>>GV was updated, typo in scene after correction outside lights off.
    If tomorrow the curtains opens and outside lights switch I will be very happy
    Hi @Bodyart,
    There is an error in I think "curtainclose" if I take it out the GV change into Test. others he will jump after the first save  into "curtainclose" while its Test time.
    I can not find what is wrong can you discover it?
    %% autostart
    %% properties
    %% globals
    if tonumber(fibaro:countScenes())>1 then os.exit() end
    local sourceTrigger=fibaro:getSourceTrigger()
    if (sourceTrigger["type"]=="autostart") then
      local debug=true
      if debug then fibaro:debug("HC2 start script at "..os.date()) end
      while true do
        local Dagdeel       = fibaro:getGlobal("Dagdeel")
     --   local eveningred   = os.date("%H:%M", os.time()-50*60)
     --   local dawn         = os.date("%H:%M", os.time()+50*60)
     --   local daytime      = os.date("%H:%M", os.time()+1*60)
     --   local curtainclose = os.date("%H:%M", os.time()-50*60)
    --dawn
    local Hour,Minute=string.match(sunrise,"(%d+):(%d+)")
        local M=(Minute -50)%60
        local exH=math.floor((Minute -50)/60)
        local H=(Hour+0+exH)%24
        fibaro:debug('dawn, '..string.format("%02d:%02d",H,M))
        local dawn  = string.format("%02d:%02d",H,M)
    --curtainopen
        local M=(Minute -5)%60
        local exH=math.floor((Minute -5)/60)
        fibaro:debug('Gordijn open '..string.format("%02d:%02d",H,M))
        local curtainopen  = string.format("%02d:%02d",H,M)
    --daytime
        local M=(Minute -1)%60
        local exH=math.floor((Minute -1)/60)
        fibaro:debug('daytime '..string.format("%02d:%02d",H,M))
        local daytime  = string.format("%02d:%02d",H,M)
    --test
        local M=(Minute +140)%60
        local exH=math.floor((Minute +140)/60)
        fibaro:debug('test '..string.format("%02d:%02d",H,M))
        local test  = string.format("%02d:%02d",H,M)
    --curtainclose
    local Hour,Minute=string.match(sunset,"(%d+):(%d+)")
        local M=(Minute +1)%60
        local exH=math.floor((Minute +1)/60)
        fibaro:debug('curtainclose '..string.format("%02d:%02d",H,M))
        local curtainclose  = string.format("%02d:%02d",H,M)
    --eveningred
         local M=(Minute +40)%60
         local exH=math.floor((Minute +40)/60)
         fibaro:debug('eveningred '..string.format("%02d:%02d",H,M))
         local eveningred  = string.format("%02d:%02d",H,M)
        fibaro:debug("Dagdeel: ".. Dagdeel)
        fibaro:debug("dawn: "..dawn)
        fibaro:debug("curtainopen: ".. curtainopen)
        fibaro:debug("sunrise: ".. sunrise)
        fibaro:debug("daytime: "..daytime)
        fibaro:debug("test: "..test)
        fibaro:debug("sunset: "..sunset)
        fibaro:debug("curtainclose: ".. curtainclose)
        fibaro:debug("eveningred: "..eveningred)
        --Sunrise
        if (dawn >= curtainopen and currentTime < curtainopen and Dagdeel ~= "Dawn" ) then
          fibaro:setGlobal("Dagdeel", "Dawn")
          if debug then fibaro:debug("Dawn") end
        elseif ( curtainopen >= daytime and currentTime < daytime and Dagdeel ~= "CurtainOpen" ) then
          fibaro:setGlobal("Dagdeel", "CurtainOpen")
          if debug then fibaro:debug("CurtainOpen") end
       elseif ( daytime >= sunrise and currentTime < test and Dagdeel ~= "DayTime" ) then
          fibaro:setGlobal("Dagdeel", "DayTime")
          if debug then fibaro:debug("DayTime") end
    elseif ( test >= daytime and currentTime < sunset and Dagdeel ~= "Test" ) then
          fibaro:setGlobal("Dagdeel", "Test")
         if debug then fibaro:debug("Test") end
          --sunset
        elseif ( curtainclose >= daytime and currentTime < sunset and Dagdeel ~= "CurtainClose" ) then
          fibaro:setGlobal("Dagdeel", "CurtainClose");
          if debug then fibaro:debug("CurtainClose"); end
        elseif ( eveningred >= sunset and currentTime > sunset and Sanco3 ~= "EveningRed" ) then
          fibaro:setGlobal("Dagdeel", "EveningRed");
          if debug then fibaro:debug("EveningRed"); end
    else
    and at the end of the debug he write test without any time?
    hehe found it evening red was not correct. Lets see if the curtains stays open today,ahahaha
    shoot me it is changing every minute! Test or curtainclose
