Node Red integration with hc2 SOLVED
I wondered if anyone can point me in the right direction to find help with setting up basic node red structures for hc2? using node-red-contrib-fibaro-hc2 by @10der .I have a node red flow which turns on my tv , turns on netflix or youtube or live tv , all with wol command.
I want to run this from a device or scene from hc2. I can post from node red to hc2 -no problem but can't find a way to get commands from hc2, any ideas ??
Edited by MARCUSP.I.L
    Understand, mosca gone.The link for mqtt vd mentions a mqtt_php.zip to www root folder. This is not included on the link page.
    Looking at new setup with pi with node red installed , external disk, all files in one user root. Little new to me so ?
    Been playing with this for a few nights following various sources, resulting a lot of nodes and dependencies installed on my mac. Clearing them out as we speak. Got the basics but wonder if all this effort is worth the expected result, only want to turn on a few tv's and media gear when i turn on a light or scene. Seems like many go for the ir solution. We'll see?
    Thanks again.
    @MARCUSP.I.L just install from node-red MQTT node-red plugin
    Look at the pic
    thats all is you do not want dancing with raspberry pi apt-get install editing configs etc
    Look at the pic
    I get it that node is the bridge
    Any luck @Jamie mccrostie? Man oh Man , round and round.....
    Understand from last reply from @10der that the set up is,
    install npm install node-red-contrib-mqtt-broker, (remembering to install it in node red directory i.e.
                            $ node-red
                             install npm install node-red-contrib-mqtt-broker) ,
                                        took ages to figure this out,thanks git hub
    That gave me a mosca broker , set up with defaults, and i used mqtt node in and mqtt node out, both with node red ip and mosca port nr.
    So far so good, get connection after 10 secs and steaming ahead....publish and subscribe to mqtt box working as a side treat.
    However , the setup for mqtt VD hc2 is a little blurred.  I set up ip and port to standard 127.0.0.1 port 11111 and changed url in main loop to my mqtt settings. Created global variable Last Check , and debugged , no messages.
    Got the basics but how on this earth do i get the hc2 device to work ?
    Little frustrated , interested less and less by trial and error , feel a distinct need to send the whole enterprise the way of the dodo.... Thanks in advance for any suggestions.
    why you do not install from UI?
    you do not need to install VD / php / etc
    just use node-red-contrib-fibaro-hc2 ease and simple!!!!
    yep much quicker
    click right drop down menu>manage pallette>install>search required node
    forget it not needed replaced by device node and server node
    Worked this out via reading old posts
    This shows Device setup I got working. It shows kitchen table dimmer at 38%
    .....And device off
    /monthly_2019_05/2060928316_deviceoff.PNG.16e85ce9ce13e09a8f8a54a6cfb96e9b.PNG" alt="2060928316_deviceoff.PNG.16e85ce9ce13e09a8f8a54a6cfb96e9b.PNG" />
    Inject node "poll" needs a "0" as payload
    totally incorrect
    ok no output
    Hc2 flashing under node with time stamp
    /monthly_2019_05/10.PNG.85a5dd1b0b667efffa9ea14ee050c73b.PNG" alt="10.PNG.85a5dd1b0b667efffa9ea14ee050c73b.PNG" />
    Good!!!!! very good!
    but you forgot about GREEN button. just press here
    right so "re-init" inject causes to continually poll
    Re device... first poll good then error?
    /monthly_2019_05/err.PNG.608c668fa703cb4123c79d6ed40aeb2b.PNG" alt="err.PNG.608c668fa703cb4123c79d6ed40aeb2b.PNG" />
    once an hour we re-init all device. we can disable it. for example. if you do not infrequent do renaming devices or add/remove devices/.
    show me flow.
    idk
    Edited by 10der
    @10derHa that error has taken over, deleted all flows deleted config nodes, still errors restarted node red still errors in cmd p
    hmmm
    Pallett empty
    show me full flow (#2)
    deleted trying to stop error, palette empty
    Even better its now reappeared
    12 minutes ago, Jamie mccrostie said:
    Must remember to hit deploy after deleting.
    it flash RED for this =)
