Node Red integration with hc2 SOLVED
I wondered if anyone can point me in the right direction to find help with setting up basic node red structures for hc2? using node-red-contrib-fibaro-hc2 by @10der .I have a node red flow which turns on my tv , turns on netflix or youtube or live tv , all with wol command.
I want to run this from a device or scene from hc2. I can post from node red to hc2 -no problem but can't find a way to get commands from hc2, any ideas ??
Edited by MARCUSP.I.L
ok. dear. lets go step by step.
so,. you send command to GA,
GA (I do not know how,. cuz I do not have any android devices at home) send command to NODE-RED.
As I can undetsnad node-red has ready for use node for interpret GA commands.
please fix me i am wrong,
so, next step we want interpret DA command via node to HC2 to set thermostat mode / temp /etc.
so 1s we shoukd understand / find commands for thermostat.
so now time for creating a new empty flow
drop HC2 device with your thermostat
also drop here inject node
/monthly_2019_07/image.png.9bd2f2d76ba39e0c8c8a93cafee5e953.png" />
so,
 - turn off
  thermostat
1 - turn on (heating)
  thermostat
back to node-red
edit inject mode
save / deploy
now we can inject nad your thermostat in Hc2 and real thermostat should be swithced to heating mode
so., now you can send any command to HC2,
on, !@MARCUSP.I.L on!
Edited by 10der
    Thanks @10der fro you assistance and indeed for the brilliant node red nodes, working great with voice commands.
    Thanking you also for recent help with Tv state , also working great with voice commands and scenes.
    Enjoy the summer :)
    working great now. Thank you for your time, brilliant !!
    @MARCUSP.I.L what module you use for GA in node-red?
    update, sorry I can't see...it's nora
    Edited by drboss
    But @MARCUSP.I.L, can you send me export of your flow with GA (this is from diagram in your post) as example for me. I beginner in node-red :-(
    hi 10der you can send me the flow pls? i want to import it to my node red, i can learn many from your flow i hope
    @10der we wait for it, when You publish new version.
    BTW, can you resolve issue: when exist in system z-wave device without "value" property FibaroNode generate debug error: "SyntaxError: Unexpected token | in JSON at position 0"
    And another small problem (new functionality) for thermostat devices: To add to queryState possibility to retrieve not only value and time of modification but property "State" or "Mode". Many device not change "value" but only "State" or "Mode"
    And last question this time: what doing inject "device/1 {}" in your flow example?
    And thanks for big good work.
    dear boss. already fixed in this ver.
    but this v er is not compatiba;e with old :(
    re-wriien
    @drboss this ver can work in two modes.
    1) simple mode. when you have only 4 device types. 2 for in 2 for out.
    you can simple hook any events for in devices and simple turn on / off any dimmers / relays
    simple drop device / setup HCx server and that's all. no MQTT no other things
    2) for adv users. HC server can produce MQTT messages for all event from HC. all it's means all evenets what you can handle by LUA in header including central events etc
    3) also you can pass some command to HC2 directy
    /monthly_2020_01/image.png.5cb70c3ab3149219fc771778e7e4f579.png" />
    ok. trying to query state of my thermosyay
    inject - devices/1483/properties/mode
    1/4/2020, 8:25:42 AM
    devices/1483/properties/mode : msg.payload : Object
    object
    value: 1
    modified: 1577024075
    yes - heating
    and last. in adv mode you can handle any evenets and values (mode / blabla etc)
    all values for devices pass to MQTT as ras values in payload
    for example
    1/4/2020, 8:27:16 AM
    home/status/1199 : msg.payload : number
    28
    1/4/2020, 8:27:21 AM
    home/status/727 : msg.payload : number
    12
    1/4/2020, 8:27:22 AM
    home/status/1283 : msg.payload : number
    45
    any others properties as object. for example
    1/4/2020, 8:28:13 AM
    home/status/1442 : msg.payload : Object
    object
    property: "lastBreached"
    value: 1578119292
    1/4/2020, 8:28:37 AM
    home/status/1131 : msg.payload : Object
    object
    property: "energy"
    value: 12631.04
    about
    just for test turn on of my neocoolcam switch. you can pass to binary swither in payload 0 / 1 / true / falase / turnOn / turnOff
    @drboss
    [email protected]
    thx
    custom actor
    /monthly_2020_01/image.png.d87a529a2616edde722ca7409944f5ff.png" />
    thx, I serched in repo by "HC2" not by  "fibaro", founded and I start testing on my system;-)
    thx
    0.0.4 1 day ago
    stop!/ it's initial version! now 0.0.8
    crazy
    Successfully published [email protected]
    npm Inc [email protected] через amazonses.com
    A new version of the package node-red-contrib-fibaro-devices (0.0.10) was published at 2020-01-05T15:05:02.897Z from
    194.x.x.x. The shasum of this package was 5b5dd65b741bc8a8b764c3c4990b94f785840bd6.
    If you have questions or security concerns, you can reply to this message or
    email [email protected].
    npm loves you.
    @drboss
    • Thanks 2
    fast progress ;-) ..0.12  now.
    BTW On
     still 0.4 when serching
    image.png.3e63014e00745675ee51eda5004ff117.pngimage.png.39d0e31c72f97e8b1786225ed7edd5ca.png
    And not posible to update:
    but after remove 0.4 and doing npm i .... it install 0.12 ;-)
    Edited by drboss
    The node help for new fibaroAPI is displayed in 'old' hc2server node:
    lol
    btw, now poller do not require inject with periodic.
    HC2 now can poll HC without inject node
    dashboard
    /monthly_2020_01/image.png.d0db48145b36156674f573eab053afd4.png" />
    Edited by 10der
    please UPDATE to .14
    bug with resource deallocation and connection to HC.
    important!
    weather forecast (zambrettiI)
    /monthly_2020_01/image.png.ece7feeaa1cbedf41db375e863455db8.png" />
    Edited by 10der
