dejavu1987 0
Hey all, I'm planning to buy Dimmer 2 to control spotlights in my kitchen. I've asked in a local Fibaro store for an advice on how the whole light installation should look like to allow Dimmer 2 to switch on/off and dim the lights. The guy said I would need to use 230V powered lights (at least that's how I understood it) - so GU10 in that case, and the use of a transformer in the circut might be a problem for Dimmer. The case is that I would like to have AR111 lights and there's much more choice in the market for ones with G53 socket rather than GU10 - in fact most AR/ES111 GU10 offer more than 15W+, while I would like to keep it around 10W each bulb. The question then is - do you have any experiance connecting 12V bulbs + transformer with Dimmer 2? Is it really a problem? or it just requires to use a specific transformer to work? Any tips are greatly appreciated.
Attached some pictures on how I believe they would like it to be and how I would like it to work.
PS. I'm no electrician, so forgive me if it's missing anything important.
Thanks in advance!
Edited by dejavu1987typos
4 answers to this question
