i would like to ask, if it is possible to control floor temperature of electric underfloor heating system. Does it matter how much watts does it have? Does it have to be calibrated first?
Did you solve this ? Heatit have thermostats that work with z wave - with either floor or air sensors or combination of both.
Watts will simply tell you the load of the heating cable and what cable size and fuse you must use.
Remember that tiled floors can be heated up to 100+ watt pr square meter while most wooden floors should have max 60 watts pr square meter, so follow installation instructions so that the heating 'loops' are not too close or too far apart.
