Pjoeloe 0
In our bathroom we have 2 lightsources; 1 in the ceiling and 1 above the mirror. Both are connected to a double serial lightswitch within 1 housing. I'd like to be able to dimm the lightsource in the ceiling, and leave the one above the mirror as is. In order to do that I replaced the current lightswitch with a Jung 535U and removed the spring in the right switch leveler (for the non-dimmable lightsource abave the mirror). And hooked it all up according to the following schema:
/monthly_2019_06/1552674634_Fibarohuidigesetup.JPG.d96ea0c505e8370166db6bca1a154e75.JPG" alt="1552674634_Fibarohuidigesetup.JPG.d96ea0c505e8370166db6bca1a154e75.JPG" />The dimmable light works fine, but the non-dimmable light is acting quite strange..
I also found some schamatics that provide 2 solutions for the exacht same issue, but I'm not sure if it will work.
6 answers to this question
