Dear all,
Pls help me for situation.
I'm try to intergate Sensibo (Smart IR for Air Conditioner),
But I got the problem when connect via Fibaro Virtual Device as:
1. With Web Browser it work.
2. But I don't how to it work in FIBARO Virtual Device, I tried but it error?
local http = Net.FHttp("home.sensibo.com",80);
local Command  = '/api/v2/users/me/pods?fields=*&apiKey=O7LHDg0TID80NUyY0xqaqlGGlycqfg';
response ,status, errorCode  = http:GET(Command);
fibaro:debug(response);
fibaro:debug(status);
fibaro:debug(errorCode);
=> Error:
[DEBUG] 18:46:21:
403 Forbidden
nginx
Hi All,
Need some help with the code:
********** ( with my one key it get a all information)
In the code of the Scene I see the Next things:
local http = net.HTTPClient()
  http:request('https://home.sensibo.com/api/v2/pods/'    << it's diffrent
Because I doesn't work for me now
Found de issue: If you looking for the Device
ID you need it pick it up from the webpage, not on the pakket.
Edited by morsink
Need help
[DEBUG] 23:13:30: nil
[DEBUG] 23:13:30: 2022-07-17 23:13:30.269814 [ fatal] Unknown exception: /opt/fibaro/scenes/37.lua:140: attempt to concatenate local 'value' (a nil value)
Upated code:
local apiKey = "SensiboAPI"
local LinkVitualDeviceId = VD id
local SensiboDeviceId = "SensiboID"
function Main()
      strCmd = fibaro:getValue(LinkVitualDeviceId, "ui.lblCmd.value")
      if(strCmd == "") then
        UpdateMeasurement(SensiboDeviceId,apiKey,LinkVitualDeviceId)
        UpdateStatus(SensiboDeviceId,apiKey,LinkVitualDeviceId)
    elseif (strCmd == "On") then
          fibaro:debug(strCmd)
        SetProperties(SensiboDeviceId,apiKey,"on","true",false)
        fibaro:call(LinkVitualDeviceId,"setProperty","ui.lblCmd.value", "")
    elseif (strCmd == "Off") then
        SetProperties(SensiboDeviceId,apiKey,"on","false", false)
     elseif (strCmd == "Auto") then
        SetProperties(SensiboDeviceId,apiKey,"mode","auto", true)
    elseif (strCmd == "Dry") then
        SetProperties(SensiboDeviceId,apiKey,"mode","dry", true)
    elseif (strCmd == "Cool") then
        SetProperties(SensiboDeviceId,apiKey,"mode","cool", true)
    elseif (strCmd == "Fan") then
        SetProperties(SensiboDeviceId,apiKey,"mode","fan", true)
    elseif (strCmd == "Low") then
        SetProperties(SensiboDeviceId,apiKey,"fanLevel","low", true)
    elseif (strCmd == "Medium") then
        SetProperties(SensiboDeviceId,apiKey,"fanLevel","medium", true)
    elseif (strCmd == "High") then
        SetProperties(SensiboDeviceId,apiKey,"fanLevel","high", true)
    elseif (strCmd == "FanAuto") then
        SetProperties(SensiboDeviceId,apiKey,"fanLevel","auto", true)
    elseif (strCmd == "SwingOn") then
        SetProperties(SensiboDeviceId,apiKey,"swing","rangeFull", true)
    elseif (strCmd == "SwingOff") then
        SetProperties(SensiboDeviceId,apiKey,"swing","stopped", true)
    else
        SetProperties(SensiboDeviceId,apiKey,"targetTemperature",strCmd,false)
          return
local function json_decode(data)
    local ok, json = pcall(function() return json.decode(data) end)
    if ok then
        return json
    else
        return nil
function UpdateMeasurement(SensiboId, apiKey, vdId)
    http:request('https://home.sensibo.com/api/v2/pods/'..SensiboId..'/measurements?apiKey=' .. apiKey, {
        success = function(resp)
            if resp.status == 200 then
                local jsonResp = json_decode(resp.data)
                fibaro:call(vdId, "setProperty", "ui.lblActual.value", "Temp: " .. jsonResp.result[1].temperature .. ", Hum: " .. jsonResp.result[1].humidity)
function UpdateStatus(SensiboId, apiKey, vdId)
    http:request('https://home.sensibo.com/api/v2/pods/'..SensiboId..'/acStates?fields=status,acState&limit=1&apiKey=' .. apiKey, {
                local Status = jsonResp.result[1].acState.on and "On" or "Off"
                local TargetTemp = jsonResp.result[1].acState.targetTemperature or ""
                local acMode = jsonResp.result[1].acState.mode or ""
                local fanLevel = jsonResp.result[1].acState.fanLevel or ""
                local tempUnit = jsonResp.result[1].acState.temperatureUnit or ""
                local Swing = jsonResp.result[1].acState.swing or ""
                local displayStatus = "Zasilanie: ".. Status .. ", Temperatura: "..TargetTemp.. " " ..tempUnit
                local displayMode = "Tryb: ".. acMode ..", Moc: " .. fanLevel .. ", Swing: " .. Swing;
                fibaro:call(vdId, "setProperty", "ui.lblStatus.value", displayStatus)
                fibaro:call(vdId, "setProperty", "ui.lblModeStatus.value", displayMode)
function SetProperties(id, apiKey, property, value, isString)
    local myJson = isString and '{"newValue": "'..value..'"}' or '{"newValue": '..value..'}'
    http:request('https://home.sensibo.com/api/v2/pods/'..id..'/acStates/'..property..'?apiKey=' .. apiKey, {
        options = {
            method = 'PATCH',
            timeout = 5000,
            headers = {
                ["content-type"] = "application/x-www-form-urlencoded;"
            data = myJson
            fibaro:debug("Response OK")
        end,
        error = function(err)
            fibaro:debug("Error : " .. err)
Main();
Edited by Krzychurychu
