kevin 34
I have a Fibaro Door/Windows sensor V1 with a DS18B20 waterproof for temperature measurement only. The battery drains very quickly while the temperature hardly changes. In 10 hours it drains 5% of battery life, that means I need to change the battery every 8 days
that will be expensive.
I only need a update interval every hour. What do you advice to use as setting? Do you advise to change the polling time interval for this device?
Parameter 12 is set on 1ºC
Thank you in advance.
Kevin
Edited by kevin2 answers to this question
