Olex 0
Hello!
I have a problem that has been for a while.
My HC2 lost remote access after a week or two, only solution is to switch the unit off then on.
This is not possible when you are away…
I have tried to restart the switch that the HC2 is connected to, that did not help, the problem is with the HC2.
I have heard about other that have installed an remote switch that power cycle the HC2 when such problem arises. This is not the solution for me, I can’t accept a solution like that since the Fibaro HC2 should work well without!
This is become very annoying; I can’t trust the system anymore.
I have removed all the z-wave security components like door locks, only the non-vital components are left. If the problem is not fixed soon with a new FW, I have to replace the HC2 with another system.
Anyone with the same problem?
Any solutions?
Edit:
I have been informed from folks at home that the automation does not work either.
So it seems that the HC2 just locked in some way, I have as informed, power cycle it in order to get it work again.
Edit2:
I have now concluded that this is more like a freeze of the system, as other have reported with version 4.540.
If it is not resolved with the next update, there will be an used HC2 for sale on eBay…
Thanks,
Edited by OlexOlex
31 answers to this question
