attempt to concatenate local 'wakeUpTime' (a nil value)
Hi there,
i have a Problem with an old scene. Since one of the last updates, i get this error:
[DEBUG] 21:56:06: --------------------START--------------------------------
[DEBUG] 21:56:06: --------- Danfoss WakeUp powered by mkshb.de
[DEBUG] 21:56:06: -----------------------------------------------------------
[DEBUG] 21:56:06: Trigger durch manuelles Starten
[DEBUG] 21:56:07: -------------- Calculate and Set WakeUpTime -------------
[DEBUG] 21:56:07: Zieltemperatur: 17
[DEBUG] 21:56:07: Aussentemperatur: 20.5
[DEBUG] 21:56:07: Es ist Sommer verwende entsprechende Werte
[DEBUG] 21:56:07: 2019-06-17 21:56:07.791861 [ fatal] Unknown exception: /opt/fibaro/scenes/27.lua:147: attempt to concatenate local 'wakeUpTime' (a nil value)
Here is the code:
Is there anybody who can help me? Thanks a Lot!
regards
Rik
Hi @Rik74 ,
Function calculateTime returns nil because some of the conditions are not met or some data is missing or changed. I suggest to add some debugging lines to this function to check what is wrong or missing.
I have tested it by changing presentHomeVar first value from "Home" to something else and I get same error. Did you recently translated global variable PresentState values from English to some other language?
