FSE 34
Greetings,
I build a scene and I like to get the name of a variable, NOT the content of variable.
Is there a way to do that on fibaro? I found some examples using _G but it is not an option on fibaro LUA framework.
The reason is that I like to read
1.if variable is a function (can be done using type(v))
2.in case is function I like to check the name and compare it with a string, so I know which function made the call.
Please help!
Edited by FSE2 answers to this question
