qsdom 2
Hi there,
I was planning to buy a Aeotec Doorbell 6, but as i onderstood from a supplier: it is only possible to use 9 of the 6 tones and it is not possible to adjust the volume with a Fibaro controler (HCL or HC2).
I asked Aeotec why this limitation
Quote Aeotec Inc.
"This is because Fibaro HC2 does not fully support the other mappings of this device, Fibaro will need to further integrate the Doorbell 6 or Siren 6 and support the "Sound Switch" command class to configure sounds and play the 30 separate tones.
We had to remove control over Configuration parameter settings as this conflicts with Z-Wave specifications and requirements for this device to be certified using parameter settings. So all sounds must be controlled via Sound Switch including volume control."
Anyone tips or advise? Another brand or ... wait for Fibaro support!?
Link to post
35 answers to this question
