Mizen 0
For the past many hours have been moving all of my devices from a Samsung Smartthings V2 to V3 hub. Most devices i’ve been able to work though - but am stuck with the Fibaro FGS-212 Relay, which i use in my garage and home gym to switch lights.
Have tried everything i can think of, and everything i've read:
… but nothing will see them reconnect. I have 3 in total across the house, so loath to write off the money. Must be something i’m doing wrong. Total time spent so far trying to do this would be well over 3 hours.
The only thing I haven’t tried is holding down the B button for 3 seconds *as* the power it switched back on - which you can infer from the manual, but it’s not explicit. I can't believe that is the solution though - it would encourage people without a second person to switch off the mains fuse to reconnect a live wire, which can't be safe.
Any help much appreciated. I wouldn't spend £180 on new relays just because I have a new hub....
7 answers to this question
