Hi
I have 2 Fibaro HC2, one pleased at my home and one at my cottage. Can i use same fibaro ID for both HC2 and that way chose which I want to open?
Yes this is possible - remove one the HC from the FIBARO ID you no longer want to use and then add the HC to the FIBARO Id you want to use for both, from within the app you can switch between multiple HCs
 <- login there, click remote access and this will display a list of HCs,
Login to the one you are removing, go to Remote Access and click the red trash can next to it and confirm deletion via the dialog that pops up and log out
Login to the one you are wanting to use, go to Remote Access and click Add New Home Center, enter the HCs serial number and MAC address, click Add Home Center at the bottom of the page, there will be a pop up dialog that confirms successful addition.
