DavidF 0
Hi all,
I'll try to provide as much detail as I can. So I recently bought HCL and Walle dimmer and Heat controller. As manuals say, devices should be google home compatible. So I happily install walli dimmer and also heat controller. I've used fibaro home android app. And I was happy because everything was working. Then I've decided to connect it google home so that I can control it using my voice. So I did as the manual said and I was able to control dimmer which was perfect and I was impressed. But when I wanted to set the temperature on my Heat Controller I was not able to. So did a lot of research and without any success.
I found that I can connect to fibaro directly through google asistant. When I tell google to connect it said "I could not find any devices", I said "ok list home center", he told me "found 1", so connect to first it seems it did but he said, "I had a problem loading your setup names". And after all the next research, I was not able to set the temperature using my voice.
So last option is to write on the forum.
So please help!
