Linus 1
Hi
Really hope for some help here, either from forum members or Fibaro themself.
I have 8 spot lights in one ceiling connected to a big transformer. These are not led lights, they are each small spot lights 35W each.
I had a normal dimmer control in the wall but changed to spring button to support dimmer 2.
After installing dimmer 2 and turning on the lights I see in the app that they go to 99%. After a few seconds they turn off.
I have set these parameters
ID 2 Size 1 Value 70
ID 19 Size 1 Value 70
ID 35 Size 1 Value 1
ID 20 Size 1 Value 0
ID 10 Size 2 Value 0
ID 11 Size 2 Value 255
And
ID 13 Size 1 Value 1 to calibrate, then of course went back to Value 0.
It is now a 3 wire connection with above settings.
After these changes clicking the spring wall button it turns on at 70 and does not go off.
But asking google to turn on I can see it does so with 99% and then turns off after a few seconds.
Also using my app I get the same result, lights turn off. Only the wall switch works now or if I say "google, dimmer ceiling to 70%".
If I go over around 85% they turn off.
I have tried with both 2 and 3 wire settings with same results.
Electric meter Wh shows 3850
Electric meter endpoint 1 W shows 237W
Electric meter root device W shows 237W
Power management root device shows Power fail event detected (both tested with 2 and 3 wire setup). Not sure what this means.
So do anyone have any suggestions on why this happens, what causes the dimmer 2 to turn off the lights when reaching to high % even though its calibrated?
Ive seen this type of problem googling but in no forum have anyone given an answer to how to solve this.
