knuth 29
A simple, rather basic question: I would like to control several devices through one control. The control could be on/off or "set to chosen common value"/off. "Set to common value" could be a dim level for dimmers, or a temperature for thermostats, where the value is not preset but determined as the control is used. I see several ways to do this, each with its own advantages and disadvantages:
1. Make two separate scenes, one to turn the device set on and one to turn them off.
Advantage: Very simple to implement for on/off control. Activated only when needed.
Disadvantage: Clutters the system with too many scenes. Tricky to achieve value control (but can be done by setting a global variable)
2. Make one scene which performs both desired actions. To dictate whether to turn on or off, either check the current status of the unit or have a global variable which toggles between On and Off each time the scene is run.
Advantage: Fewer scenes than option 1. Activated only when needed.
Disadvantage: Still messy to perform value control
3. Make a virtual device, with push buttons for on/off or a slider for value control.
Advantage: Very intuitive and simple interface
Disadvantage: The VD is run every 3 seconds, which is unnecessary as there is no data harvesting involved.
I lean towards doing this as a VD, and could include a long fibaro:sleep command in the LUA code to avoid the code (which would essentially be empty) being run every three seconds. Question: Will a sleeping VD respond immediately to buttons or sliders being used, or only after the sleep period ends?
Or more generally: How do you prefer to manually control a set of devices, through scenes or VDs?
