Hi all,
I need help for a (tricky) thing:
I added 2 underwater temperature sensors on my Fibaro smart implant.
Now i need to calculate the middle value of both sensors over a.e. two days.
Example:
-Sensor 1:  8 degree on day 1 and day 2
-Sensor 2: 10 degree on day 1 and day 2
- middle value: 9 degree
This value should trigger a global variable like "summer" - for middle value >8 degree and "winter" for middle value <8 degree.
I need this to know when i have to feed winter pellets for my kois and to trigger a scene that switches my pond pumps.
I´m not really good into lua. I thought about to adapt other scripts that calculate time or to build a table that stores the values and triggers a global variable or maybe to use a virtual device but... What should I say? - I´m a noob :D
Also searched different keywords in this forum and searched with google but i didn´t found a scipt that does this.
It would be so nice if anyone can help me with this. I feel really sad that I don´t get it.
Benjamin
6 answers to this question
Benjamin
 Could look something like this - not exactly sure how you want to calculate the value and how often you want to sample the sensors - the value for a day, is it mean, max or min values? Daytime or whole day? In the example below it’s just the average over the last 48 hours.
You need to create fibaro global "season" and "samples" (or other names you make up)
And set SENSOR1/SENSOR2 to the deviceIDs of the sensors
    Wow! Thank you so much!
    I understand what your script likes to to (only until calculate average ? but I´m shure I never get it by myself ?)
    You´re right - I only need average over 48 hours.
    I copied script and changed sensor ID´s but debug shows error:
    [DEBUG] 18:30:26: 2019-10-02 18:30:26.445453 [ fatal] Unknown exception: /opt/fibaro/scenes/87.lua:31: 'do' expected near 'then'
    Of course, I can´t figure out why this error appears...
    I added global variable "season" with "summer" and "winter"
    Did I understand you right that i only have to add simple variable without predefinied value "sample"?
    Thanks again for your quick help with this.
    Sorry, I changed a for loop to a while loop and missed the 'do' keyword in
    I changed the original post.
    and spelled 'samples' wrong -fixed.
    Yes, you don't need predefined values.
    You don´t have to be sorry for your help :D
    Ok i changed code and also changed
    there is a "p" missing in third samples. Only for everyone else that uses your code...
    Do I have to fill new variable "samples" with a value or why does debug say that samples is nil?
    Quote
    [DEBUG] 19:07:45: Sensor1: 14, Sensor2: 13
    [DEBUG] 19:07:45: 2019-10-02 19:07:45.730758 [ fatal] Unknown exception: /opt/fibaro/scenes/87.lua:27: attempt to get length of local 'samples' (a nil value)
    Sorry to bother you but without your help...
    Quote
    [DEBUG] 19:16:16: Sensor1: 14, Sensor2: 13
    [DEBUG] 19:16:16: 2019-10-02 19:16:16.926241 [ fatal] Unknown exception: /opt/fibaro/scenes/87.lua:27: attempt to get length of local 'samples' (a number value)
    That's strange. Can you post the whole scene as it looks now for you?
    To be real safe that samples doesn't contain some old value, you could add the third line in function sample()
    This works!
    I added debug into "set global" for summer and winter.
    Quote
    Thanks alot for this nice piece of coding. I was trying to fin a solution along 4 month ?
