Air humidity control due to less humidity <40%
master_jo1
Hi folks,
i will present you my new gadget in my living room.
Had some trubels with air humidity, less then 40%.
I searched a gadget to rise up the humidity.
Found one and it works perfect together with the wall plug.
Luftbefeuchter Ultraschall, Homech Raumbefeuchter
Actual I switch it manually on and of.
Next step, using some humidity sensors as triggers for automatically steering the humidity.
looking forward how it works.
Best regards
  • Actually as I said only combined with wall plug.
    The humidity issue <40% I analyzed with a stand alone sensor.
    Which Zwave sensor i will use for the next step as trigger sensor I do not have evaluated yet.
    Main reason for the humidity drop is the fireplace in the living room. Whether I will use a humidity sensor or a temperature sensor at the fireplace. If fireplace on switch humidifier on...
    Do you have a recommendation?
