Air humidity control due to less humidity <40%
Hi folks,
i will present you my new gadget in my living room.
Had some trubels with air humidity, less then 40%.
I searched a gadget to rise up the humidity.
Found one and it works perfect together with the wall plug.
Luftbefeuchter Ultraschall, Homech Raumbefeuchter
Actual I switch it manually on and of.
Next step, using some humidity sensors as triggers for automatically steering the humidity.
looking forward how it works.
Best regards
hmm, what humidity sensors did you use?
    Actually as I said only combined with wall plug.
    The humidity issue <40% I analyzed with a stand alone sensor.
    Which Zwave sensor i will use for the next step as trigger sensor I do not have evaluated yet.
    Main reason for the humidity drop is the fireplace in the living room. Whether I will use a humidity sensor or a temperature sensor at the fireplace. If fireplace on switch humidifier on...
    Do you have a recommendation?
