RobVeenis 0
Folks,
We have a strange situation in our main bedroom.
The setup was 3 x TBK home double switch 230V 1 main light and 2 at the bed.
1 Fibaro roller shutter 230V and 2 vision security window sensors. 1 Fibaro multisensor, eurotronic radiator thermostat and 1 everspring moving sensor (outside very close)
Distance to the HC-2 app. 5 meters, one wall, one floor.
Everything worked fine untill the TBK home double switch for the main light disapeared from the system . Suddenly I lost as well communication with some other units in the room.
The right window sensor, the everspring moving sensor and the thermostat.
We replaced the TBK with a normal switch (since it was not the first time that we had problems with it) and replaced all the batteries in the units that did't communicate anymore.
After a reconfiguration of the mesh network and with some exculding and including we had most of the units back online.
Only strange thing is that the right window sensor is visible in the system but not when I want to select it in a scene as you can see in the screenshots.
I am logged in as "superuser" rebooted the system and have no clue anymore what to do.
Sorry for the long post but I want to inform you as good as possible.
Anybody a suggestion?
Edited by RobVeenisupdated question
