2 hours ago, dcspock said:
Is this really the case? Is checking the status not also sending a command to the device to receive its current status?
No, commands like "if tonumber(fibaro:getValue(999,"value"))==0" do not communicate with the device. "Checking the status" as you call it is what "polling" is for (Lua: fibaro:call(817, "poll")). Checking values in Lua uses a cached value, it does not communicate with the device. All recent devices report status eg when you push a button and the device changes state, it will notify your HC. And if you send "turn ON" (on a healthy network) you can be almost certain, the device is doing what you've asked. It is a valid assumption to cache that value and avoid polling after a change. There are corner cases, and it is a bit more complex, but I think it would lead us too far (in this topic) to discuss them.
Is this more efficient than sending an on/off command?
Because checking values in Lua uses a cached value, it is more efficient. But what about "polling" a device? That is going to cause real extra communication before sending an on/off so polling is to be avoided unless you have some sort of reliability problem (or a very, VERY old device, one that does not report eg switch status). And things like "soft reconfigure" and "read configuration" cause a truckload of communication. Usually the cached value is correct, if it is not then your situation warrants investigation... with Zniffer ;)
Or is the HC2 taking the last status it has got in its database?
Status is cached in the sqlite3 database on your HC2/HCL.
    6 hours ago, dcspock said:
    Is this really the case? Is checking the status not also sending a command to the device to receive its current status? Is this more efficient than sending an on/off command? Or is the HC2 taking the last status it has got in its database? I hope its the first...?
    Yes, it really is the case.
    The state of devices is stored locally on the HC2. When you check the state all you are doing is checking the last reported state as stored in the HC2, so it's an internal request within the HC2.
    When you send a command e.g. on/off, you are sending a zwave command which the HC2 zwave controller executes. You can create a lot of traffic and also probably add a little to CPU by not checking the state of a device before making a change to its state.
    More importantly, very happy you found the device and fixed the problem. Well done!
    EDIT: OMG, I clicked on page 3 of this thread after writing my answer and as I should have half expected @petergebruers answered your question about 10 times more thoroughly than me. haha!
    Edited by amilanov
    On 11/19/2019 at 11:03 AM, petergebruers said:
    If it is not there... my script cannot help you.
    I had checked the API, it is simply not there... that why my comment Getting from Fibaro's device ID to the node is easy - the other way around seems impossible... ;-)
    @dcspock
    It's not so hard to get device ID from node ID
    @cag014 I have liked your post because of the Lua code you have posted, but I would like to point out that your code would not return anything in @dcspock's case because the device was simply missing on HC2 (it was not in /api/devices). People might falsely assume that your Lua code has some magic tricks to find devices that have gone missing, this is not the case. Only Zniffer made it clear that such a device existed.
    @petergebruers
    Indeed I don't want users to believe in Lua magic.
    I've just answered to @dcspock's statement that impossible to get device ID from node ID assuming if he can get node ID therefore device exist.
    • 4 weeks later...
    Hi, I can't retreive anymore on silicon labs site pc programmer, zniffer and associate tools. Only pc controller, sdk ... are accessible. Am i doing something wrong ? or an idea on why it has been removed ?  can somebody provide them to me ? I also have an zwame.me that i'll need to flash, so the full pack dev pack is wellcome :)  thanks guys for your help.
    EDIT: many thanks to @amilanov that has resubmitted them to me !
    Edited by Tony270570
    • 1 month later...
    Hi
    I'm happy to read that reading a devices value from LUA does not cause any z-wave traffic because the reading comes from a cached value. Just for the record, is this the case for devices read through the HC2 API?
    13 minutes ago, tnesheim said:
    Hi
    Yes, it is.
    • 1 month later...
    Guest Kint
    Hi
    I don't know if this is the right tread, but I experience some issues when I try to do external backup on my HC2.
    It's been creating backup for more than 15 hours and the prosess bar have not moved at all. How long time is this supposed to take? The prosess bar is "rotating".
    Regards
    Kint
    @KintA backup usually takes two to three minutes so something has gone wrong with your backup.
    Try restarting your HC2. If it does not respond to the power switch, you can disconnect the mains voltage for approx. 10 seconds. Then try again.
    Also tell us which version of firmware you have, but I hope it is version 4.500 or later and that you have then removed the Recovery stick.
    Guest Kint
    @RH_Dreambox Thank you. I unplugged the HC2 and all look good. I have firmware 4.580 so all seems ok.
    • 1 year later...
    10tender
    a saw your picture and wonder where i can find this script to my pc
    i had it in the past but lost it
    /monthly_2019_11/29554131-86F4-4BF0-B3CA-7850FC0B8768.thumb.jpeg.3f17f3c7ed3af22de2104b73098cca9f.jpeg" />
    • 1 month later...
    On 7/9/2021 at 5:39 AM, Kage said:
    10tender
    Why do you want the picture?
    I fixed my zwave issues without any pictures :)
    not the picture duh!?
    But the script for it on de desktop
    thx btw
