I (plan to) use 5 FGS 223 to supplant Insteon modules  to control 3 lighting points ( or 3 circuits ). These are controlled from 2 different switch locations. 1 of the FGS 223 is configured as a slave (DIN module). Ideally one would use associations ( response times...).
When associating 1 fgs223 endpoint 1  with  the corresponding endpoint 1  on the 2nd fgs223 ( association set in  assoc group 2) , the associations do not work.
When i replace the FGS 223 with A Qubino flush 2 relay ( and associate it ) , the Qubino as master can perfectly control the FIB fgs223. The other way around - FGS223 to Qubino - does not work .
Resetting multiple times 1 of the FGS 223  back to  factory defaults made the FIBARO parameter template unavailable ( setting of parameters has to be done in the basic approach , parameter by parameter... )
question to the community : has anybody experienced difficulties in associating multiple FGS 223?
HC2  version 4.560
txs
Hi, I get same issue also associations are not working for me.
Also scene activation is not working.
If somebody can put some light what is done wrong or why it is not working - would be nice.
BR
Piotr
